Hello, I try to build an fireware example from your FX3 SDK on Eclipse, but when I build a project I still have the same error.
make all
Building file: ../cyfx_gcc_startup.S
Invoking: ARM Sourcery Linux GCC Assembler
/bin/sh: arm-none-eabi-gcc: not found
arm-none-eabi-gcc -x assembler-with-cpp -I"/home/thierry/Desktop/Cypress/FX3_SDK_B724/cyfx3sdk/firmware/u3p_firmware/inc" -Wall -Wa,-adhlns="cyfx_gcc_startup.o.lst" -c -fmessage-length=0 -MMD -MP -MF"cyfx_gcc_startup.d" -MT"cyfx_gcc_startup.d" -mcpu=arm926ej-s -mthumb-interwork -g -gdwarf-2 -o "cyfx_gcc_startup.o" "../cyfx_gcc_startup.S"
make: *** [cyfx_gcc_startup.o] Error 127
I try to resolve it since few days but I need advise and help.
It is my first project on FX3 SDK.
I tried to look for a solution with FX3 GUID, FX3 Manual Programmer and FX3 support but I didn't it.
Hi Thierry,
Looks like the compiler is not able to find the location of arm-none-eabi-gcc. Are you following the steps given in 11.2.2.1 of FX3 programmers manual to the dot?
Did you install a version of FX3 SDK and then migrate to another version?
Anand
Hi, I think I found the solution... I download the bad SDK for my application.
Thierry
I too cannot build the example firmware. It complains that it cannot find cyfx3gpio.h.
Description Resource Path Location Type
cyfx3gpio.h: No such file or directory gpio_test.c /Fx3BootAppGcc line 1 C/C++ Problem
make: *** [gpio_test.o] Error 1 Fx3BootAppGcc line 0 C/C++ Problem
I also have 2 warnings that:
Invalid project path: Include path not found (C:\Documents and Settings\Administrator\My Documents\Eclipse\include). Fx3BootAppGcc pathentry Path Entry Problem
My Documents\Eclipse is the Workspace path.
Hi , I am able to build the project, after building project without error, I am not able to debug the error and run, instead getting the same error as below ones.
error while launching command gdb-- version
Thank you, please help on this.
HI Joyce,
1. You need to make sure that you have installed a vaild version J-link tool( I guess you use it) and have a correct configuration.
2. You need to make a correct Debug configuraionin Eclipse. Check with the video attached.
