USB Superspeed Peripherals
I'm trying to set different frequency on PIB block. I found that not all dividers are workable when the source is CY_U3P_SYS_CLK. Here are some values that can work.
4(100M)
8(50M)
10(40M)
16(25M)
32(12.5M)
Others, for example, 48, 64, 100, 128, can't work.
Why?
Rover
 Hi Rover,
I just tested these settings and they all work fine. I get the exact expected clock on the PIB block.
Can you please check again?
Shashank
 Hi Rover,
How do you come to the conclusion that those specific divider values do not work? Are you not able to see a clock on the PCLK pin?
Shashank
Hi Shashank,
Thanks for reply. When I use the dividers that I mentioned, the host can't recognize the DVK, no device found in control center, neither output on PCLK pin (I checked on scope).
Rover
Interesting. It works this morning. All values are workable...
It seems that is due to isDllEnable setting in CyU3PPibClock_t structure. If it's true then most values will fail.
