USB Superspeed Peripherals
GiSa_4520796
New Contributor II
I am using Multicasting example firmware which came with SDK.I want to transfer the same data from P-Port to U-Port and S0-Port.
    dmaCfg.prodSckId[0] = CY_FX_EP_PRODUCER_SOCKET;
    dmaCfg.consSckId[0] = CY_FX_EP_CONSUMER_1_SOCKET;
    dmaCfg.consSckId[1] = CY_FX_EP_CONSUMER_2_SOCKET;
I declared above prod and cons sockets as
#define CY_FX_EP_PRODUCER_SOCKET            CY_U3P_PIB_SOCKET_0/* Socket 1 is EP1 OUT */
#define CY_FX_EP_CONSUMER_1_SOCKET        CY_U3P_UIB_SOCKET_CONS_1  /* Socket 1 is EP1 IN  */
#define CY_FX_EP_CONSUMER_2_SOCKET        CY_U3P_SIB_SOCKET_0/* Socket 2 is EP2 IN  */
After the above changes,the device is not enumerating in Control center.Why?
Srujana.
Rashi_Vatsa
Hello Srujana,
Please confirm that did you start and initialize the sib block before creating the DMA channel
Rashi
Rashi
Rashi_Vatsa
Hello Srujana,
Please let me  know that is the CyU3PDmaMultiChannelCreate API passing successfully or is it returning error?
    apiRetStatus = CyU3PDmaMultiChannelCreate (&glChHandleBulkLp,
            CY_U3P_DMA_TYPE_MULTICAST, &dmaCfg);
    if (apiRetStatus != CY_U3P_SUCCESS)
        CyU3PDebugPrint (4, "CyU3PDmaMultiChannelCreate failed, Error code = %d\n", apiRetStatus);
        CyFxAppErrorHandler(apiRetStatus);
Please get the debug prints
Rashi
Rashi
GiSa_4520796
New Contributor II
Hi Rashi,
     Just now i checked this and came to know that it is returning error 64.
Below is my DMA Channel Configuration
    dmaCfg.size  = size;
    dmaCfg.count = CY_FX_BULKLP_DMA_BUF_COUNT;
    dmaCfg.validSckCount = 2;
    dmaCfg.dmaMode = CY_U3P_DMA_MODE_BYTE;
    dmaCfg.notification = CY_U3P_DMA_CB_PROD_EVENT | CY_U3P_DMA_CB_XFER_CPLT;
    dmaCfg.cb = CyFxBulkLpDmaCallback;
    dmaCfg.prodHeader = 0;
    dmaCfg.prodFooter = 0;
    dmaCfg.consHeader = 0;
    dmaCfg.prodAvailCount = 0;
Srujana.
Rashi_Vatsa
Hello Srujana,
Rashi
Rashi
