USB Superspeed Peripherals
I have Cypress cyusb3.sys source code now and the code includes some script files such as cybuildall.bat, cywdkbuild.bat and MAKE_INX.exe.txt.But the cyusb3.sys source code only supports Windows 7 x64 and earlier version. I want to know how it supports Windows 8.1 even higher system version? Should i modify the code or change the way the compiler? Thank you very much!
You can use the CyUSB3 drivers on Win 8 and above. Please find the link to download. You can use these drivers without any need for modification.
http://www.cypress.com/knowledge-base-article/drivers-ez-usb-fx1-fx2lp-and-fx3-kba94413
I am using FX3 development kit, and now i want to modify the source code of cyusb3.sys to add some custom features. For example: i can send control commands or data at the specified memory address.
Would you be able to provide the latest source file of cyusb3.sys which support Windows 8.1 even higher version? Thank you very much!
