USB Superspeed Peripherals
        hi, we are designing a USB 3.0 dongle with cy3014 ,but we want to use a USB 3.0 standard-A plug , not a standard-B plug .Is it possible ? TX/Rx pins on FX3 are defined as Rx+ Rx- Tx- Tx+ ,not the same as other chips, or the Standard-A pins definition. So we need to exchange TX/RX lines, but is this the right solution ? if possible, where can i found one schematic example use Type-A plug with cy3014 ?
prc_1505996
Contributor
   Please share your mail id so that I can share the details.
        chufutao@outlook.com Regards
