USB Superspeed Peripherals
MaFa_974161
Contributor
Hello.
I'm using FX3 device.
I develop a board without EEPROM and so I use Cypress BootLoader.
It's a very flexible system because if I have a new FW release I give it to my clients
and a custom software can reset the FX3, restart BootLoader and load new release.
But I have a question.
Can I retrieve USB port physical address using CyUSB.dll ? Or I have to develop custom driver ?
YatheeshD_36
We do not have any Cypress specific APIs to retrieve the port and hub number.
Yatheesh
YatheeshD_36
You can use API to retrieve the USB Address of a connected cypress device. Please refer to the CyUSB.pdf section "6.4 IOCTL_ADAPT_GET_ADDRESS" present in the FX3 SDK under doc -> SuiteUSB.
Yatheesh
MaFa_974161
Contributor
I dont' want USB address,
I want this address for example Port_#0001.Hub_#0001
YatheeshD_36
Yatheesh
KoKo_1287401
New Contributor
I would suggest looking at the source code for USBView in the WDK.
