USB Superspeed Peripherals
   I read several posts about FX3 programmatically switch to different speed modes,  let's say we have a FX3 dev board that plugs into a xHCI port (support super speed).
   Here, what we want is to have FX3 dev board switched to three different speed modes ( plug into xHCI port), from one of the post I know that it can be switch between HS and SS,  but not FS,  can Cypress fix this?
Henry
NoriakiT_91
Edited:
The SDK has an API function to prevent FX3 from connecting as a High-Speed device as follows.
NOTE: Call this API before ConnectState API.
Example Code:
/* Make USB Full Speed Connection. */
        apiRetStatus = CyU3PUsbForceFullSpeed(CyTrue);
        if (apiRetStatus != CY_U3P_SUCCESS)
            CyU3PDebugPrint (4, "Full Speed Conn Failed, Error code = %d\n", apiRetStatus);
            CyFxAppErrorHandler(apiRetStatus);
    /* Connect the USB Pins with super speed operation DISABLED. */
    apiRetStatus = CyU3PConnectState(CyTrue, CyFalse);
        CyU3PDebugPrint (4, "USB Connect failed, Error code = %d\n", apiRetStatus);
Noriaki
Please let me know the use case of your requirement.
sai krishna.
NoriakiT_91
Edited:
Example Code:
Noriaki
