FX3 on mac
Hi there, I am getting this error when I run "sudo make" ont he examples folder of the MAc SDK.
sudo make
g++ -o cyisowrite_test          cyisowrite_test.c               -l cyusb -l usb-1.0
clang: warning: treating 'c' input as 'c++' when in C++ mode, this behavior is deprecated
ld: library not found for -lcyusb
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make: *** [all] Error 1
Anyone have any idea?
Have you tried using the SDK. Are the firmware example building?
