FX3 Many to one setup
Hey,
I have some troubles setting up the FX3 in a many to one configuration.
I downloaded the Example-project for the firmware from this website. It was called "GPIF_Example2" .
Trying to read data with the Streamer program show that all packeges are failed.
I did not change the code anywhere before trying it out on the board. Is this a known problem or is it something that I can fix?
Jesper
Did you keep the !WR signal Low? (I.e GPIO 17 (CTL0) pin which is !WR should be connected tpo ground for this project to work.
- Madhu Sudhan
