USB Superspeed Peripherals
EsPo_3827446
New Contributor II
Please send me link for FX2LP programming guide.
for example:   CPUCS = 0x02;                 //12MHz operation , CPUCS[4:3] = 10.
                       PINFLAGSAB = 0x08; // FLAGA - EP2EF
for Reference programming guide How to set hex value for clock  or set port ? with explanation
With Regards,
Esakki
YatheeshD_36
Hello Esakki,
Please refer to FX2LP Technical Reference Manual: https://www.cypress.com/file/126446/download
Details of all the registers are available under Chapter 15. Registers.
Also, you can refer to other chapters like Slave FIFO and General Programmable Interface for detailed explanation of their implementation.
Most of the helpful documents on FX2LP is listed in this KBA: Help Content for the CY3684 FX2LP DVK - KBA87890
Yatheesh
YatheeshD_36
Hello Esakki,
Yatheesh
