I referred AN4053 Streaming Data Through Isochronous or Bulk Endpoints on EZ-USB® FX2™ and FX2LP
I followed the chapter 2 Associated Project Files, I unable to create hex file and I share the screenshot below
Esakki
Hello Esakki,
As stated in the build output windows, you are using a restricted version of Keil, which restricts the code size that can be built to a maximum of 1000H limit.
You will have to purchase a licensed version of Keil for building the projects with size greater than 1000H.
The Application note has pre-built binaries (.hex and .iic) in the Binaries folder. You can use them for testing.
Yatheesh
Hello Esakki,
Yatheesh
