Eval Board Bypassing vs Schematic Checklist
Looking at the supply bypass recommendations there are discrepancies hopefully someone can address. On the AN70707 HW Design Guidelines & Schematic checklist, Section -  Device Supply Decoupling, U3TXVDDQ &  U3XXVDDQ call for 22uF caps. However in the DVK schematics they are 2.2uF. Which is the correct recommendation? Thanks
22uF is the correct recommendation. I'll check with our guys on the 2.2uF on the DVK issue.
Anand
Thanks!
