USB Superspeed Peripherals
 I am using FX3 to connect with both TI & NEC xHCI, FX3 works fine with NEC, but can't even emulate with TI.  But TI xHCI works fine with USB3 Disk. anyone has this situation before?
Board Info--
UTB242 (uptech), USB 3.0 4-Port
TI (VEN_104C & DEV_824)---
Driver ver 1.6.2.0
Driver date 2011/1/14
NEC(VEN_1033 & DEV_0194)---
Driver ver 1.0.20.0
Driver date 2010/3/23
I couldn't find that board (UTB242) on the TI's website.
Please update the host driver and try again.
I have tested with the TI's PCIe based USB3.0 host controller add on board and It enummerates without any issues.
sai krishna.
 Thank you for your help, i have updated the drier to 1.12.18, and emulation work just fine.
 Good to hear that. 🙂
