I'm working on a project where I need to get video stream through USB using a CSI-2 compatible camera. I intend to interface CYUSB306X: EZ-USB® CX3: MIPI CSI-2 to SuperSpeed USB Bridge Controller with Raspberry Pi Camera (http://in.element14.com/raspberry-pi/rpi-8mp-camera-board/raspberry-pi-camera-board-v2/dp/2510728)
Since I just need the Camera and CX3 on my circuit board, I was hoping if anyone could provide me with the schematic for this interface. I could only find the kit schematics on the website, I need the minimal components.
Also, would I need a dedicated programmer to program CX3?
Hi Sonu,
You can check with out design partner e-consystems for reference designs or Cx3.
For a minimal design you would need only the CLOCK, PMODE, RESET, MIPI_CSI, USB Intreface pasrts in the schematics.
- Madhu Sudhan
Hi Madhu,
I have a few more questions:
1) Is I2C Buffer required for MIPI interface or I2C Flash interface? Is it possible to exclude it?
2) I want to flash firmware using USB. So, Can I eliminate SPI Flash and I2C EEPROM?
