USB Superspeed Peripherals
I'm working with AN75779.  I'd like to see the output from the various CyU3PDebugPrint() calls.  I'm not seeing much at the uart pins.  Is there some initialization I need to do?  What baud, parity, databits, stopbits, etc... am I looking for?
--Adam
CyU3PDebugPrint() works fine on my dev board, but not on my actual hardware.  At this point I'm going to assume it is a hardware problem and move on.
 Ok, looks like the dev board uses GPIO 48/49 for TX/RX.  My actual hardware has GPIO 55/56.  It's not obvious to me what i need to do in the code to switch them.
--Adam
 (Oh 115200 8N1, for anyone else searching the forums for the serial info)
