USB Superspeed Peripherals
        hi, can I use to output system clock signal for peripherals by using GPIO ?? Is it CyU3PGpioSetClock??
 You can't output the internal clocks but you can set up a PWM on the pin. Look at CyU3PGpioSetComplexConfig() and the serialif_examples\cyfxgpiocomplexapp example project.
        thank you
