USB Superspeed Peripherals
lechc_282591
New Contributor
Hello, I changed the crystal(19.2MHz) to oscillator. The voltage amplitude of the clock signal(clkin) on my board is 0.8V(19.2MHz)and the board is not working now. My question is that what should the voltage level of the clock be. 0.8V is too low or sufficient?
Thank you
Lehua Chen
lechc_282591
New Contributor
I check it by applying external clock to the Clkin pin on the FX3 evaluation board. The amplitude of the clock (19.2MHz) should be larger than 1.8V. Otherwise, the chip will not work. Thanks
Lehua Chen
many times  mine is  0.5-1.5V  or  less  than 2v     ,but  it is  work  normal
I am seeing around 0.8V on my working board.
sai krishna.
