IMPORTANT: Cypress Developer Community currently doesn’t allow sign-in to prepare for the upcoming transition. To learn more, check out our announcement.
USB Superspeed Peripherals
The FX2 has the ability to load a short (~140 byte) device descriptor file from EEPROM, which simply instructs the FX2 default bootloader to enumerate with a specific VID/PID for loading firmware from a host via USB. This is different than booting user firmware itself out of I2C -- rather than loading user firmware from the EEPROM, only a device descriptor is stored, and user firmware is loaded from the host. Does the FX3 also include this ability, or is it forced to enumerate with Cypress VID/PID for USB boot? And if it does include this feature, is the format of the required EEPROM image the same (starts with 0xC2, etc.)?
Please look at     www.cypress.com/?docID=31024 You should find it useful.
The link mentioned above is not working. Could you please upload a relevant one?
here you can see how to change VID PID of FX3 with I2C eeprom.
http://www.cypress.com/?app=forum&id=167&rID=51560
regards
lumpi
regards
lumpi
