IMPORTANT: Cypress Developer Community currently doesn’t allow sign-in to prepare for the upcoming transition. To learn more, check out our announcement.
USB Superspeed Peripherals
EsRa_2282511
New Contributor II
HI, Am using CX3, I tried to configure the UART in register mode and set baudrate above 115200 (say 230400). I can't able to read the correct data in teminal. Is there any configuration need to set to acheive this baudrate in CX3?  Thanks in advance
abhinavg_21
Please share your firmware. Which host application you are using?
Have you changed the baudrate in the host application?
Abhinav
