agba_3844561
5 likes given First like given
I'm following this example: http://www.cypress.com/documentation/application-notes/an84868-configuring-fpga-over-usb-using-cypre...
Using a CYUSB3KIT-003 instead of the 001.
In section 4 Operating Instructions it says to connect some pins (of FX3 SuperSpeed Explorer Kit) to:
  • Pin 23 of J7
  • Pin 31 of J7
  • Pin 27 of J7
  • Pin 19 of J7
  • Pin 37 of J7
However I don't seem to find the pins on my board. I read: http://www.cypress.com/file/139246/download ​ and on the pinnout description is maps the GPIO's (GPIF II Interface) with other pin names according to use but I don't seem to find a bunch of pins under the name J7 that contains the pins listed.
Couldn't find it either on http://www.cypress.com/file/140296/download
I am looking for a block called J7 that has numerous pins but I cannot find it. This seams as a basic question so I'm sorry about it.
SrinathS_16
Please look at the page 6 of the attached document. The 20 pin headers on the CYUSB3KIT-003 are indicated as J6 and J7.
Srinath S
SrinathS_16
Srinath S
