CYUSB3014 UVC dataflow
Hi Cypress,
I am using cyusb3014 to transfer image dataflow through UVC, but there is no any image on AMCap.The attached file is dataflow captured by busbound.Is the format of video data wrong? If it's wrong, then what is the correct format?
Thank you!
Please add a UART UAB bridge to check the UART debug logs. Please let me know what do you see on the UART , do you see any API failures? Please check for commitbuffer API failure if you are getting. Also, I assume you are using AN75779 based project. If you have made any changes in FX3, please let me know what have you changed.
