CX3 RefClock 27 MHz
VlKh_2251656
Level 5
Level 5
10 likes given 5 likes given First like received
Good Day.
Please, tell me
We are now using a video camera developed on the basis of a Denebola reference board (CX3 and OV5640).
But our quartz oscillator (RefClk source) has a frequency of 27 MHz, and not 19.2 MHz as in Denebola. Other quartz is analogue as Denebola.
Tell me. What exactly should be changed in the source code in order for everything to work correctly?
Mipi settings ? How ? What value ?
I2C, SPI settings ?
PLL ?
Many thanks.
Please configure CX3 using the same parameters in the screenshot below.
Ensure that your project inlcludes the library ov5640.a
YangyangC_06
750 replies posted 500 replies posted 250 replies posted
You need to adjust the parameters inside red box below.
Dear,
Anything similar to this?
// Configuration parameters for VGA for the OV5640 sensor
CyU3PMipicsiCfg_t cfgUvcVgaNoMclk_HS =  {
    CY_U3P_CSI_DF_YUV422_8_2,       // dataFormat
    1,                            // numDataLanes
    0x1,                          // pllPrd
    90,                            // pllFbd
    CY_U3P_CSI_PLL_FRS_125_250M,    // pllFrs
    CY_U3P_CSI_PLL_CLK_DIV_2,     // csiRxClkDiv
    CY_U3P_CSI_PLL_CLK_DIV_8,     // parClkDiv
    0x00,                         // mclkCtl
    CY_U3P_CSI_PLL_CLK_DIV_8,     // mClkRefDiv
    640,                          // hResolution
    0x01                          // fifoDelay
PLL settings ?
Only in this place?
Nowhere else?
Many thanks.
Doesn't it make it difficult for you to send a ready-made configuration file?
At least for modes 640*480 for connections USB2 and USB3 ?
I can't make MIPI calculator work ...
Yes, many thanks.
But I not understand, how I can compile its configuration file and add it  (or replace old file) for apply new 27 MHz settings ?
Please, tell me.
Many thanks!
