USB Low-Full-High Speed Peripherals
        I want to do with the ps2 usb communication cy7c64215 Can you help
saiprashanthc_
        There is no direct user module that supports PS2 in CY7C64215. If you want to really implement PS2 in CY7C64215, then you need to do by polling using GPIO. Seconldy i would like to inform you that encore II has PS2 user module. You can use encore II for developing your application directly with ease.
Sai
