USB Low-Full-High Speed Peripherals
qiko_3575871
New Contributor
Hi
Could somebody give me help. Data is error. showing as the picture.
1.PNGmady
Sananya_14
Please attach the snippet of the TD_Poll function from your firmware where you are committing the data. Can you also explain what your application is?
Sananya
Sananya_14
Sananya
qiko_3575871
New Contributor
Thanks for your reply.
The application is USB Control Center which is installed by FX3SDKSetup_1.3.4_win.exe.
Sananya_14
I meant to ask about the complete implementation of your project and whether you are using the firmware from any of our application notes? Please share your schematic if possible and also the code snippet as requested earlier.
Sananya
qiko_3575871
New Contributor
Thanks!
We find out the root cause. There is some error about our firmware.
