USB Low-Full-High Speed Peripherals
I have installed CySuiteUSB_3_4_7_B204.exe and cy3684kit_RC8, both have drivers and firmware directory etc.  Which to use with my custom hardware board of CY7C68013A? If I could install only one of above software to develop my custom board?
AjayB_76
cyusb3.sys is a later version of the driver which has support for USB3.0.
Please use this driver.
Thank you very much, But my device is cy7c68013a, it's a usb2.0 device. All documents I can get says to use cyusb.sys not cyusb3.sys. So I am confused with this. And what's the difference between suite and cy3684 with examples, tools, firmware?
Where I can find for Windows 10 ?
