I am following the docs on how to compile and get the examples to compile. I am not having any luck.
I am using mac book pro OS X El Capitan 10.11.1
g++ -o cyisowrite_test            cyisowrite_test.c            -l cyusb -l usb-1.0
clang: warning: treating 'c' input as 'c++' when in C++ mode, this behavior is deprecated
In file included from cyisowrite_test.c:7:
./../include/cyusb.h:18:10: fatal error: 'libusb-1.0/libusb.h' file not found
#include <libusb-1.0/libusb.h>
1 error generated.
make: *** [all] Error 1
can you please confirm that the folder structure is intact as provided in the package or if any inlcdues are missing?
-Madhu Sudhan
Please see screen shot. All i did was unzip and cd to the examples directory like the README.txt explains and did make and you will see the error i get.
Please create a Tech Support Case with Cypress.
