USB Low-Full-High Speed Peripherals
David_Zhang
New Contributor II
hi   Cypress:
       The problem with cy7c68013a-56ltxc is that the host computer needs to send 512Byte or integer multiple data to receive it. If the data sent is less than 512Byte, it cannot be received. In the relevant protocol of USB, it should be necessary to send relevant operation instructions to achieve non-512byte acceptance. The customer needs to know how to operate. Whether there are relevant operation documents;
YangyangC_06
YangyangC_06
