USB Low-Full-High Speed Peripherals
mikic_3745566
New Contributor
Will this device work OK under Win10 (64bit)?
Sananya_14
Please uninstall the device from the device manager and manually bind the device to the cyusb3.sys driver, the latest version is available with the FX3 SDK. Please let us know if the device does not come up under the PORTS section as well?
Sananya
Sananya_14
Please let us know if you have configured the device for UART interface? Please attach a screenshot of the device manager on connecting the device.
Sananya
mikic_3745566
New Contributor
Sanm:
Thanks. Please see the attached screen-shots.
Sananya_14
Sananya
mikic_3745566
New Contributor
I had previously installed the software for the CYUSBKIT-003 SuperSpeed Explorer kit. After I uninstalled all software for both the CYUSBS234 and CYUSBKIT-003 SuperSpeed Explorer, I then re-installed the software for only the CYUSBS234 kit …then everything worked OK. I really don’t know how to explain why this happened.
Mike K.
