USB Low-Full-High Speed Peripherals
        I have developed, with the help of this community, some modified NAND firmware for the CY7C6803x controller and 2K NAND chips. I could designed and produce a memory stick but wonder if there is already a memory stick on the market that uses these chips? Who better to know then the developers.
        Hi, Yep. There are memory applications available in the market using this chip. Regards, Anand
        > Hi, Yep. There are memory applications available in the market using this chip. Regards, Anand Anand. Thank you. I need to actually find said devices so that I may purchase one. Do you know of any specifics?
 In the linux SDK, you can find fx2_download.cpp file in the path: cyusb_linux_1.0.4\gui_src
There functions for RAM load and EEPROM load for FX2LP.
 Sorry, wrong post.
