USB Low-Full-High Speed Peripherals
 Is there any way how to know how much data are still remained in buffer at slave fifo mode in pc applicaion?
 You can create a vendor command in the firmware to pass the byte count of a particular endpoint to host
That's good idea thanks
But i have query.
1. Is there any commands to find remained data Instead of counting passed data.In slave fifo mode.
2.  If no, how can i coding  to your idea?
