I want to use external SRAM for cy7c68013a-128pin(fx2).
Because firmware larger than the internal memory of EZ-USB.(internal memory 16k, my firmware size 21k)
How to connect PSEN, RD, WR, CS, OE, EA. and build option.
( I used SRAM CY7C199D-10ZXI.)
my build option
.\hex2bix -i -e -m 0x2000 -f 0xC2 -o filename.iic filename.hex
what is probrom?
Yes, you are right. If you want to load into the external SRAM from the EEPROM, use the following command to generate the .iic file-
hex2bix -i -f 0xC2 -e -m 0x8000 -o filename.iic filename.hex
You can also check the following KBA-
Regarding the GAL program, please refer to the User Guide at the following path- C:\Cypress\USB\CY3684_EZ-USB_FX2LP_DVK\1.1\Documentation\EZ-USB(R) Development Kit User Guide.
Sananya
- Please refer to the Application Note EZ USB FX1/FX2LP Boot options at http://www.cypress.com/file/43391/download
-How are you loading the firmware into the external SRAM? Do you get any errors while running the hex2bix utility?
Best Regards
Sananya
I already refer to the Application Note.
But I don't know my mistake.
I am downloading firmware to EEPROM. It is EEPROM first byte 0XC2. and It is changed to iic file to useing hex2bix.
I don't know how can I download firmware to the external SRAM. I think -E option of hex2bix is having boot loader. so I think boot loader is loading the firmware.
Isn't it?
I want to know run of CPLD(GAL22LV10C-7LJ in CY3684kit. How Can I get program or program run sequence?
Thank you
Sananya
