I can not flash firmware EEprom Fx2lp
siac_2560096
First reply posted First question asked First like given
Hello Guys,
                  please find attachment below..,
                  I can`t flash firmware EEPROM on Fx2lp..
SrinathS_16
- Please let us know the connection of JP3.
- Kindly, probe the SCL, SDA lines and let us know if there is any activity.
EDIT:
- Please check if the SCL and SDA lines are at logic HIGH before the EEPROM is programmed using the Control Center.
Srinath S
SrinathS_16
EDIT:
Srinath S
