USB Low-Full-High Speed Peripherals
I get a problem with the CY7C68001 chip recently.It Could communicate with PC successfully before.But now,it doesn't work normally.PC Can't identify the device.The external controller is TI F2812 MCU.So I want to know whether the CY7C68001 chip is damaged .How to  identify it from the pins or registers? Could anyone who has the similar experience give me advice.
thanks.
If you suspect that your chip is damaged, please create a Tech support Case. Our engineers would analyze the issue and recommend for failure analysis if required.
-Madhu Sudhan
The problem is solved when I use another CY7C68001 chip.
Travel
