To avoid re-inventing the wheel, has anyone ported the FX2 Bulkloop example from Keil to SDCC / Eclipse to run with CyUSB.sys on Windows that they could share ?
Dave
In case anyone else has the same question, here is a good start:
You can already get it if you get the FX3 dev kit. It contains a version of Eclipse that has all the necessary tools (except for SDCC itself, you need to get it yourself).
You can create a new project using the BulkLoop as an example.
I did a video on how to set it all up (it's not very good but hopefully it'll get you started.)
Even if it is not the bulkloop example, this may help anyone (even after a few years) who is looking for a Linux startup point:
GitHub - shenki/cystream: Cypress EZ-USB FX2 CyStream with SDCC
Martin
