USB Low-Full-High Speed Peripherals
karac_3142546
New Contributor II
What is the license of the CyUSBSerial library on Windows? (On Linux and Mac I got it cleared up in my previous questionCyUSBSerial library licensing terms.)
But the Windows version has the same reference to a file <install>/license/license.txt, which doesn't exist.
Nor can I find any mention of a license in the SDK install tree.
The closest thing is a file named 'eula.cyclic', which turns out to be a HTML file, but these licensing terms seem mention only using software on Cypress hardware, which is not applicable for the CyUSBSerial library (I think?).
I tried to re-install the SDK, but it did not prompt me to accept any licensing terms.
thanks in advance,
kalle
Sananya_14
Please find attached the license file which applies to any Cypress software. The reference path mentioned for the SDK isnt proper, we'll look into it.
Sananya
Sananya_14
Sananya
