I used to make a product using CY7C63723C-SXC IC the program used was an assembly.
its purpose is usb to ps/2 converter and it has a separate cpu on the output ans. so it drives the keyboard ans mouse.
currently,the cy7c63723c-sxc is called the production stop.
It you want to use the cy7c63310 ic, how should you use it.?
1. copy the existing data to the cy7c63310 without changing it. do i have to change only i/o port from pcb.
2. or Should i re-programme to cy7c63310?
3. do you have a tool that converts automatically?
4. our company doesn't have enough people to do asm, is there another service company?
ofcouse all have all source problom
5. the best way is there is a way to get about 500pcs
I will answer your questions one by one here:
A. It is not possible to use the same hex file. There may be changes required on the PCB also.
A. Yes, the firmware has to be redone for CY7C63310.
A. Such a tool is not available with us.
A. We are not aware of any other company who can develop firmware in asm.
A. You can post your development requirements in this forum. Someone who can develop in asm can respond to your request. You can take it from there.
Sampath Selvaraj
Sampath Selvaraj
You can also make use of our Cypress Design Partner Program to find a developer who can suit your requirement.
