8051 memory bus behavior model to drive an FPGA simulation
dasu_2655076
I am using CY7C68013 to drive an FPGA through the external memory bus. is it possible to find a simple 8051 external memory behavior bus model in this community?
it will take me some to create it from scratch.
I should put this thread in USB group. but for some reason, it won't allow me to log in.
appreciate your help.
David Sun
SrinathS_16
Hello David Sun,
- The CY7C68013 datasheet (Page 42 and 43) explains the timing diagram to drive a device through the external memory bus. Hope you are referring to this. The below link contains the device datasheet.
http://www.cypress.com/file/138911/download
Srinath S
SrinathS_16
Hello David Sun,
Srinath S
