USB Hosts Hubs Transceivers
PoVe_3939176
New Contributor II
I'm trying to configure the HX3C by making use of ACA docking feature but not able to understand how the HX3C detects the ACA dock and USB type- C port.
Resistor value is required which is used as RID value at Type-C port, so not able to select resistor value.
kindly please let us know
Pooja Vernekar
pooja@rioshtech.com
RajathB_01
Hello Pooja,
If upstream of HX3C is a Type-C receptacle, then power negotiation will occur over CC lines and ACA Docking through RID will not be available.
Rajath
RajathB_01
Hello Pooja,
Rajath
