Can any on help How to develop firmware code for this CY7C65640A-LTXC tetrahub controller
which ide is used for developement ?
CY7C65640A is a fixed function part and the firmware cannot be modified completely. The VID/PID/DID values can be configured by using an external serial SPI EEPROM. The hub functionality is already loaded into the built-in firmware.
Srinath S
Srinath S
Hi Srinu,
You don't need to write any firmware code when you use a HUB
