We will use CY7C65632-28Pin in our design and we are planning to drive USB load switch via PWR# pin. In community there is a similar discussion(Re: cy7c65642-28 pin 12cSDA pin) which is related with my question but differently I would like to ask in which cases PWR# will be driven low? It is not clear. For example once a device is connected to one of downstream ports what will be the state of PWR# pin(is it driven low, or high-Z) after enumeration is done(Datasheet says that host may power each port by sending a SetPortPower request)? And the second case if the hub gets a trig from one of OVR# pin, then does it change PWR# pin state?
Zafer Çalışkan
- cy7c65632-28
- pwr
Hi Zafer,
If the PWR# pin is set for polarity as active low, it will be low when the downstream port is powered after enumeration.This state is after host has sent a SetPortPower Request for the particular port. When hub detects overcurrent on any of the OVR# pins, the host is notified and it disables power for the particular port. The PWR# pin will then be in deasserted state or high till power is enabled again.
Sananya
Hi Zafer,
Sananya
