Hello everyone i made PCB design based on the reference design PB-811 and CCG3PA Car Charger Reference Design using Southchip i changed CYD1775 of car charger to CYD1771 so it will work as power bank i connected both CCG3PA with I2C as the design of this reference design ACT2861-201-REF03 but the problem is the exemple code in PSOC creator is based on PMW between CCG3PA and BUCK/BOOST and not on I2C as on both reference design.
can i please have the code exemple of https://www.cypress.com/documentation/reference-designs/ez-pd-ccg3pa-usb-cpps-power-bank-solution-us...
so i can start with ?
Hi ,
Please kindly start to contact with local Cypress FAE with get firmware project of reference design ACT2861-201-REF03.
Lisa
Hi ,
Lisa
i contacted what i found on cypress website site to be local cypress FAE for france i'm not sure it is really that.
but is that any requirement to get the code exemple or a fee ? just for information.
hello again so i didn't get the answer cypress FAE that i contacted what is is the purpose of reference desing ?
Hi ,
Could you please kindly share your contact information to us? I will process this request further.
Thank you for your understanding.
Lisa
what contact information should i share with you and should i share it here in the thread or private mail? thank you
