USB EZ-PD Type-C
Ivan_Lee
Contributor
Dose CCG3PA SDK have any API to read VBUS current ( mA ) Or there is another way?
I check "pd_hal_measure_vbus_cur(port)” function, it seems just a empty function.
YiZ_31
Have CCG_CABLE_COMP_ENABLE been defined in your project?
If it's not enabled, then pd_hal_measure_vbus_cur could be empty. You can comment out #if CCG_CABLE_COMP_ENABLE to enable its feature.
Eddie
YiZ_31
Eddie
Ivan_Lee
Contributor
Sorry, i want the API to read current, not voltage.
YiZ_31
Sorry, my former answer was incorrect. So I modified the answer.
Eddie
