USB EZ-PD Type-C
beyuc_3712261
New Contributor II
In my design I use the billboard controller CY7C65210 to control the HDMI converter but the controller takes DP/DM from one of the output port of the USB hub IC rather than the USB-C connector. will it work?
beyuc_3712261
New Contributor II
Thanks Rajath.
The chip has a microcontroller embedded. should i create any code to make it work? or I can use the default codes built inside?
RajathB_01
Can you please clarify which chip you're referring to? The billboard or hub controller or CCG?
Rajath
