USB EZ-PD Type-C
bohic_4007501
New Contributor
As above.
ShifangZ_26
Hi ,
It is possible. And it is per Type-C and Power Delivery SPEC. You just get those information on ID Header VDO, you can get VID.
And Product VDO.
Lisa
ShifangZ_26
Hi ,
And Product VDO.
Lisa
bohic_4007501
New Contributor
Thanks Lisa. My next question is: can I send custom command such as "Discover Identity" to the connected device from CCG chip?
ShifangZ_26
Hi ,
You could send custom command with function:
    if (is_vdm_task_idle(port) == true)
        /* Set VDM Task to send DISC ID VDM */
        set_mngr_task(port, VDM_TASK_DISC_ID);
        set_mngr_event(port, VDM_EVT_RUN);
Lisa
