Section 3.8.2 in the Development Kit Guide for CY4502 describes programming via CC line using the 2 board CY4501. The need for the two board CY4501 is explained below Figure 3-15:
Standard DFP implementations can only initiate USB-PD commands when a USB-PD power contract is in place. Since the DFP cannot setup a power contract while a power consumer (Upstream Facing Port or UFP) is not present, programming the CCG2-based EMCA cable requires both a host (DFP) and client (UFP) to be connected…
Is there any reason the CY4502 can't be programmed over CC lines using the CY4532 kit connected to one end of the CY4502 as long as the other end of the CY4502 is connected to a client (UFP)?
References:
- CY4502 EZ-PD™ CCG2 Development Kit Guide @ https://www.cypress.com/file/159241/download
- CCGx Programming Methods - KBA97271 @ https://community.cypress.com/docs/DOC-10128
- Programming EZ-PD CCG2, CCG3, and CCG4 Using PSoC Programmer and MiniProg3 - KBA96477 @ https://community.cypress.com/docs/DOC-10129
Greg
ispn:39567:1:0
ispn:39570:1:0
l1:314:1:0
Hi Greg,
It shall can be CC programmed for CY4502 with the hardware setup you have been mentioned. Kindly let me know if you meet any problem. The User Guide of CCG2 is based on CCG1 and if you want to MTK/Baster programming CCG2 cable, you have to use CY4501.
Lisa
Hi Greg,
Lisa
