IMPORTANT: Cypress Developer Community currently doesn’t allow sign-in to prepare for the upcoming transition. To learn more, check out our announcement.
USB EZ-PD Type-C
HuEd_3452391
New Contributor
I would like to get CC pin voltage in order to check the cable type. Any API to get the CC pin voltage?
BRs
ShifangZ_26
CCGx power SDK is not offering the voltage value retrieve back.  But, below API returns the current status on the CC line (rp_cc_status_t or rd_cc_status_t), you refer this API.
static uint8_t pd_typec_get_rp_rd_status(uint8_t port, uint8_t channel, bool rd_idx)
    dpm_status_t* dpm_stat = dpm_get_status(port);
    PPDSS_REGS_T pd = gl_pdss[port];
    uint32_t rval = 0;
    uint32_t temp;
    uint8_t out;
    uint32_t status;
    bool change = false;
    /* Set default output. */
    if (dpm_stat->cur_port_role == PRT_ROLE_SOURCE)
        out = RP_OPEN;
    else
        out = RD_RA + rd_idx;
    /* Connect both the Up/Dn comparators to the active CC line. */
    if (channel == CC_CHANNEL_2)
        rval = (PDSS_CC_CTRL_0_CMP_DN_CC1V2 | PDSS_CC_CTRL_0_CMP_UP_CC1V2);
    temp = pd->cc_ctrl_0 & (PDSS_CC_CTRL_0_CMP_DN_CC1V2 | PDSS_CC_CTRL_0_CMP_UP_CC1V2);
    if ( temp != rval)
        pd->cc_ctrl_0 &= ~(PDSS_CC_CTRL_0_CMP_DN_CC1V2 | PDSS_CC_CTRL_0_CMP_UP_CC1V2);
        pd->cc_ctrl_0 |= rval;
        change = true;
         * Set the threshold of the Dn comparator to Ra level and the Up
         * comparator to Rp open level.
        rval = ((thresholds[dpm_stat->src_cur_level_live][0]) << PDSS_CC_CTRL_0_CMP_DN_VSEL_POS) |
            ((thresholds[dpm_stat->src_cur_level_live][1]) << PDSS_CC_CTRL_0_CMP_UP_VSEL_POS);
    else
        /* Set the Dn comparator to vRdUSB and the Up comparator to vRd1.5A. */
        rval = ((thresholds[RD_ROW_NO][rd_idx]) << PDSS_CC_CTRL_0_CMP_DN_VSEL_POS) |
            ((thresholds[RD_ROW_NO][rd_idx + 1]) << PDSS_CC_CTRL_0_CMP_UP_VSEL_POS);
    temp = pd->cc_ctrl_0 & (PDSS_CC_CTRL_0_CMP_DN_VSEL_MASK | PDSS_CC_CTRL_0_CMP_UP_VSEL_MASK);
    if (temp != rval)
        pd->cc_ctrl_0 &= ~(PDSS_CC_CTRL_0_CMP_DN_VSEL_MASK | PDSS_CC_CTRL_0_CMP_UP_VSEL_MASK);
        change = true;
    if (change == true)
        /* Delay to allow references to settle. */
        CyDelayUs (50);
    status = pd->intr1_status;
    if (((status & PDSS_INTR1_STATUS_VCMP_DN_STATUS) != 0) && ((status & PDSS_INTR1_STATUS_VCMP_UP_STATUS) == 0))
            out = RP_RD;
        else
            out = RD_USB + rd_idx;
        if (((status & PDSS_INTR1_STATUS_VCMP_DN_STATUS) == 0) && ((status & PDSS_INTR1_STATUS_VCMP_UP_STATUS) == 0))
            out = RP_RA;
    if (dpm_stat->cur_port_role == PRT_ROLE_SINK)
        if (((status & PDSS_INTR1_STATUS_VCMP_DN_STATUS) != 0) && ((status & PDSS_INTR1_STATUS_VCMP_UP_STATUS) != 0))
            out = RD_1_5A + rd_idx;
    return out;
Lisa
ShifangZ_26
    uint32_t rval = 0;
    uint32_t temp;
    uint8_t out;
    uint32_t status;
        out = RP_OPEN;
    else
    if ( temp != rval)
        change = true;
    else
    if (temp != rval)
        change = true;
    if (change == true)
        CyDelayUs (50);
            out = RP_RD;
        else
            out = RP_RA;
    return out;
Lisa
