Jun 10, 2019
08:15 AM
Jun 10, 2019
08:15 AM
We are evaluating a design based on the CYPD3171. When opening the cydwr file pins diagram. I noticed that the CC1 and CC2 assignments are not correct:
- Pins diagram in PSOC Creator has CC1 on pin 14 and CC2 on pin 15 (see attached)
- Datasheet has CC1 on pin 15 and CC2 on pin 14
- Main board schematic for CY4532 EVK also shows CC1 on pin 15 and CC2 on pin 14.
I'm running PSOC Creator 4.2.
Can anyone confirm that this is wrong on the PSOC Creator Pins diagram?
Is there an errata associated with this?
11:57 PM
Jun 10, 2019
11:57 PM
Hi
Thank you for your thread.
It seems PSOC Creator Pins diagram is incorrect, we'll start the process to correct it.
Please follow CCG3PA Datasheet for the correct pin diagram.
Eddie
11:57 PM
Jun 10, 2019
11:57 PM
Hi
Eddie
