Hello we have been using the PSOC4 device cyt2b9 for our product, we need CAN messages without the filters being applied to them , current example code only supports CAN classic bit mask filtering. i.e only `CANFD_CONFIG_STD_ID_FILTER_CLASSIC` is used in example. there is no example for `CANFD_CONFIG_STD_ID_FILTER_RANGE`
is there any way to receive messages from multiple CAN IDs. we don't want to setup classic can filters for each can-id as there may be 20 of them
please provide sample code for above requirements
Kiran Bhosale
PSoC 4 MCU
Hi ,
Can you please confirm the target MCU again? You have mentioned that you're using PSoC, but the part number is CYT2Bx , which appears to be Traveo II family. Kindly mention the full part number.
If the device is Traveo II- you may refer following AppNote [AN220278] for the details on CAN-FD configuration-
Ashish
Hello Ahish,
Thanks a lot for you reply , sorry the mcu is Traveo II CYT2B93CAE, and the "AN220278 -How to Use CAN FD in Traveo II Family" doesn't have an example for range filter, neither "TVII_Sample_driver_library_6_6_0" . So just by reading the datasheet i tried to configure it in below mannner
But there is no CAN-FD interrupt at all
please provide an example code which sets "range-filter" for CYT2B9
