Dears.
(1) ICLAMP_ABS is clamp current of protection diode in IO, MCU. Right?
(2) Could you tell me the difference between ICLAMP_ABS and ICLAMP_SUPPLY_POS_ABS?
Kevin Han.
Automotive Traveo_II
- clampcurrent
Hello @WonjinHan ,
SID18:
This is the specification of the clamp current per I/O pin.
SID18A:
This is the specification of the clamp current that can be passed through one I/O supply pin when the clamp current flows through the pin adjacent to the I/O supply pin.
SID18B:
This specification is the specification of the clamp current that can be passed through one I/O ground pin when the clamp current flows through the pin adjacent to the I/O ground pin.
SID18C:
This specification is the specification of the clamp current that can be passed to the I/O supply pin of the entire MCU. However, this does not apply when the clamp current flows through the pin adjacent to the I/O supply pin.
SID18D:
This specification is the specification of the clamp current that can be passed to the I/O ground pin of the entire MCU. However, this does not apply when the clamp current flows through the pin adjacent to the I/O ground pin.
Hello @WonjinHan ,
SID18:
SID18A:
SID18B:
SID18C:
SID18D:
