TRAVEO™ II
WoHa_955446
Contributor
Dears.
I'm wondering what does that suffix "M"  means like PWM_M_x  in TVII-B-E-2M (CYT2B9 Series) datasheet.
And what is difference between "PWM" and "PWM_M"?
KevinHan.
Swathi
Hello Kevin,
PWMx_M_y refers to TCPWM 16-bit PWM with motor control line out, x-TCPWM block, y-counter
number.
Please refer to the Table - 'Pin Mux Descriptions' of the device datasheet.
Swathi
Swathi
Hello Kevin,
number.
Swathi
WoHa_955446
Contributor
Hello Swathi.
Thank you for your feedback. I got your point that is clear.
Kevin.
